Wet Belt replacement recommendations
"Per wet belt" I have not had heard as much about the failure rate, but what I do hear about is the types of failures from those that...
May 6, 2024
Mark_Pookie
2011 Ford Fiesta - Engine oil leak between engine assembly and below intake manifold
Thank you so much again Andy for your tips! I will discuss this with the mechanic and hopefully he doesn’t need to remove the whole...
May 6, 2024
Mark_Pookie
Hi Andy, Thanks for your quick response, Is it possible that the oil leak might come from the PCV valve and not from the housing? Upon...
May 6, 2024
Skeetathon
AC Compressor top right mounting bolt hole?
I have a question ive had the ac without the top right mounting bolt cause it doesn't line up. All bolts have snapped off i had to drill...
May 6, 2024
Daveb40258
2016 Titanium HB 1.6L 111k miles HELP
here are the csv files if anyone notices anything out of the ordinary let me know. At the top there are numbers. I put the info needle...
May 6, 2024
Mark_Pookie
Thanks for your response, I also had the engine oil changed after the mechanic checked up the oil leak. The mechanic cleaned up the...
May 6, 2024
richie9425's post
Hi, I have bought a 2015 1L Ecoboost Fiesta on 35,000 miles and someone has warned me about the wet belt issue. Couple of questions: 1...
May 6, 2024
Your question regarding the lifespan one can reasonably expect from the wet belt design is a very difficult one to answer. But, the...
May 6, 2024
My 2012 Fiesta Powershift has a 3000 or so rpm rev limit on D. Can i use it as launch control or is it bad?
It's simply BAD. The powershift transmission is not a performance oriented gearbox. It does have a more favorable spread of gear ratios...
May 6, 2024
saltiel
WuNgUn's post
{Vid} Upgraded my 2015 to Sync 3 with Android Auto!
Some of you probably know my Bronco back story. I guess having Sync 4 in the truck spoiled me, so I HAD to upgrade My Ford Touch in my...
May 5, 2024
tearza
Stuck lift door because of shatter glass
My glass on the back of my vehicle lift gate was shatter and some of the glass got down into my hitch release and I'm now unable to...
May 4, 2024
Daviddwaynewood
2013 Fiesta radio quits
I have a 2012 fiesta SE and I have the same problem with my radio. I have to shut off the engine and back on to get the sound to come...
May 4, 2024
TPMS!
Today omw to work at 30 min mark the light came ,then when I left work it came on inmediatly ,tomorrow morning we'll see ,but you are...
May 4, 2024
TPMS!
They may just have a dead or weak battery - the sad part about all this is it seems to fit the issue of that callout - it will only let...
May 4, 2024
richie9425
May 4, 2024
