Nissaki
Cooling fan doesn't kick in!
Update from my last comment:- The cooling fan works when I turn the A/C on in the cabin, not the heater!
Jan 24, 2025
gfh77665's post
I agree econo. Keeping it outside is all can do as is. I do wash it often and wax it occasionally. In time I will bite the bullet and...
Jan 24, 2025
Deano
Fiesta 1.0 eco boost strange brake light issue
When I press the brake pedal the passenger and upper tailgate brake lights come on but the driver's side lights go out. Any ideas?
Jan 23, 2025
Nissaki
The cooling fan works when I turn the heater on in the cabin
Jan 23, 2025
Y
Yowakawaka
Ford Fiesta Shutting off
Hey @Handy Andy I think I’ve fixed the problem. I was driving and when I was at lights I could hear some clicking. I got out and it...
Jan 22, 2025
You should confirm that the cooling fan is capable of running. Aka jumper wire it to a power supply to confirm that the fan motor...
Jan 22, 2025
B3NN3TT
System Off to Save Battery Message - is this normal?
ADDENDUM: I have since been told that the BMS needs to be reset regardless, as the on-board system will still be operating under the...
Jan 22, 2025
Nissaki
This is baffling me and I would like some assistance, if possible, please. I have a 2002 Mk5 ford fiesta 1.4 petrol. My cooling fan...
Jan 22, 2025
LionsTooth's post
2015 SE HB Build
Clunky, grindy, weird, noises from the front of the motor recently, turned out to be a water pump going south. Replaced the timing belt...
Jan 22, 2025
Supersyrosaurus
LED DRL (Daytime Running Light) not working on passenger side after replacement but all other functions of headlight working
Exterior Cosmetic & Lighting Modifications
I replaced the front passenger side headlight and all the functions of the headlight are working except for the daytime running light, I...
Jan 22, 2025
Razziel24
Wheel well liners
Hello. I havent been able to find info regarding this... But all of my wheel well liners are breaking apart, (I have a 2019) I dont...
Jan 21, 2025
Razziel24
Oil pressure light
Not really. After that episode I just did an oil change, there was no visible oil leaks, and so far the garage floor shows no signs of...
Jan 21, 2025
k1oud
2014 Fiesta S Cruise Control Retrofit 7 vs 9 wires
I just made an account to thank you two for coming up with a solution for other folks with 7 wires "problem". I've been searching for a...
Jan 21, 2025
shd
Air con blowers not working - fiesta 2015
Hi all First post so be gentle with me please :) I’m trying to resolve an issue with the wife’s car that has recently happened To...
Jan 21, 2025
