LionsTooth
It's a few hours job. Some knuckle scrapping for sure as it's a bit tight. You can find the process on YouTube.
Feb 1, 2025
LionsTooth
Wytt H's post
👋 This place is great for looking at repairs for my beater (my fiesta is about as base as you can get.)
Feb 1, 2025
We are rooting for you! Its rough everywhere... Thank you for stopping by to let us know you're ok!
Feb 1, 2025
So how difficult is the timing belt replacement for a home mechanic? Regarding my mechanical aptitude, I once repaired a Leica M4 35mm...
Feb 1, 2025
RKW
Hello everyone! Just picked up my Ranger Raptor this week. Looking to have some fun with it!
Feb 1, 2025
rickjohnson728
2015 fiesta se 1.0 p0299 code
no sign of external leaking ...performed a compression test today only 70 psi on number 3 ...looks like head gasket is culprit
Jan 31, 2025
Antb97
Oil pressure light
Took my car in today, here's what they did. 1. Checked PCV and its valve, no oil in the intake tubes 2. Pulled turbo tube like from...
Jan 31, 2025
Vale94Esq
Media Button stopped working
Did you find a solution?
Jan 31, 2025
Vale94Esq
Teke's post
So my fiancé’s sister just got a 2017 Fiesta a month ago. Last week her media button stopped working. You press the button and it goes...
Jan 31, 2025
Bennett
High temperature fault car won’t start
Hi did you manage t o sort y Hi did you sort your issue?
Jan 31, 2025
rickjohnson728
I was driving and experienced a loss of power. check engine light came on (p0299) code low boost ... noticed white smoke exhaust ...
Jan 30, 2025
Patrickk55
Aftermarket stereo lost my tcs.
Handy Andy, Thanks for the response. I will post a couple photos as soon as I have a chance. The hill assist light is on, the tics...
Jan 30, 2025
Kogur
2018 Ford Fiesta Ecoboost O2 sensors
Where is the upstream O2 sensor located? I have done quite a bit of googling but cannot find pics or videos for this car. My daughter's...
Jan 29, 2025
Patrickk55
I bought my daughter a 2012 fiesta se. when I got it, the car had a non-functioning aftermarket stereo installed. I bought a new...
Jan 29, 2025
Nissaki
Suukool's post
2015 fiesta se 1.0 cooling fan not working
I've tried just about everything replaced the thermostats , and temp sensor, relays and fuses. Checked wiring with multimeter, bought a...
Jan 29, 2025
