Phil_F_NM's post
Keep your fingers crossed for me, regarding my previous post. I took a walk in the rain down to autozone and picked up a bottle of brake...
Feb 13, 2025
Feb 13, 2025
So here I am in one of those precarious pickles... Got laid off in June, finally got some per-diem work a full hour drive away, so I use...
Feb 13, 2025
Norm
2016 Ford fiesta won't spin over in the cold
Forum Help Center
The car won't spin over in cold but as the ambient temperature gets to around 50⁰ F it spins over and starts right up it has a new...
Feb 12, 2025
Muzzy fiesta
Oil usage
Good afternoon all I have a 1litre eco boost on a 2014 and it's using alot of oil. There is no visual leaks any advice as I'm being told...
Feb 12, 2025
Little noises 2011 Automatic
Can the mechanic take a look?
Feb 12, 2025
1
1st time ford
I wonder if it is the alternator ..
Feb 11, 2025
RosieRumble
Ford Fiesta 2014 - Drivers Side Window/Light Fault
A year later and I'm including an update... Last year, a temporary solution was found to my above issue, by disconnecting and...
Feb 10, 2025
party ford se
Brake Caliper still siezed after parts cannon
2014 fiesta 1.6 here from California. I bought this car with a single siezed brake caliper. (Front passenger caliper) when I cracked the...
Feb 9, 2025
party ford se
2014 fiesta 1.6 P219A Code
2014 fiesta 1.6 non turbo here. And this P219A code will not go away. I've replaced all of the spark plugs , upstream 02 sensor, and...
Feb 9, 2025
1
1st time ford
High everyone, this is my first post here. I had a 2011 with a blown motor popped in my lap, so i had a mech do a motor swap. Starts ...
Feb 9, 2025
1
1st time ford
Feb 9, 2025
2014 hazard switch repair
This might be in the archives but I'll add my experience. The hazard switch worked intermittently. Sometimes it took multiple presses...
Feb 9, 2025
Barry Cooke
focus gearstick gator.
Hi I have a 2010 ford focus 1.6. I wish to renew the gearstick gator.Does any one know if they were modified that year. I cant find one...
Feb 9, 2025
2015 SE HB Build
I certainly hope that you have healed up from the broken leg! Is everything good now?
Feb 9, 2025
