1st time ford
Little noises 2011 Automatic
Thx for replies gents ... yes mechanic looked /listened at the issue and couldn't tell ... The old motor had a leak in rad which led...
Feb 17, 2025
2014 fiesta 1.6 P219A Code
The faults will eventually set another check engine light for other issues of performance - but right now it may be as for a flimsy seal...
Feb 16, 2025
party ford se
Wheel still locked up
Thanks for the reply. The mechanical issue theory makes sense to me. Maybe I can try to install the Junkyard ABS unit. But just swap...
Feb 16, 2025
party ford se
Yes. It is an automatic transmission. If I had a timing or camshaft sensor issue, wouldn't I at least get a timing code or some other...
Feb 16, 2025
Fiesta 1.0 EcoBoost MHEV Start moving trouble
Yes. Your car, being a Mk8, has a number of drive modes to choose from. You may just need to read your owner's manual and set it how you...
Feb 15, 2025
Alex_Kalisi's post
Hello. I'm still having this problem. Ford dealer can't solve anything, they say everything is fine with the car. This is very bored.
Feb 15, 2025
LionsTooth
Key not found...
Whew, for those "orange buttons" made me think they've found a way to clone your fob and left it behind when they saw you arrive. Glad...
Feb 15, 2025
LionsTooth
Key not found...
Yeah...battery was fine but plugged a new one in, anyway. As a precaution, I lightly glued the board back in place. My fear is this...
Feb 15, 2025
You may be releasing the clutch just a bit too soon. Why? The RPM drop when you apply throttle at a low RPM - the engine can not spin...
Feb 15, 2025
Oil usage
"New engine" That may mean the oil consumption is due to a bad turbo - might want them to recheck that assembly - it can plug up your...
Feb 15, 2025
party ford se
Fiesta Build Projects
2014 fiesta 1.6 here from California. I bought this car with a single siezed brake caliper. (Front passenger caliper) when I cracked the...
Feb 15, 2025
Popped open the hood after dropping the wife off for a saturday painting get together she does, and I beheld a small amount of spray of...
Feb 15, 2025
Oil usage
If the engine actually is new, It might be burning a little oil because it's breaking in. When you say "new," do you mean a brand new...
Feb 15, 2025
Find a better mechanic.
Feb 14, 2025
Alex_Kalisi
Feb 14, 2025
