"Engine Malfunction" on radio for 2012 Fiesta S sedan
The typical simple OBD-II Code reader checks emissions, and engine, fuel, and even AC if it's programmed enough to look for it, but the...
Mar 4, 2025
Tensioner? Should have been replaced anyways as part of the cost - so this is a "cleaning" I too - don't appreciate. As a delivery...
Mar 4, 2025
Well, replacing both switches, unhooking the battery for 15 mins DID NOTHING. I don't have a clue what to do now.
Mar 4, 2025
I noticed the brake switch plunger as well wasn't working as it should...do these both normally stop functioning in a car that's less...
Mar 4, 2025
Brake pedal wasn't able to depress the blue switch plunger all the way as it's not depressing correctly.
Mar 4, 2025
The blue switch plunger isn't coming back out all the way. It's a cruise control switch. WHY would my car have a CC switch when it...
Mar 4, 2025
FiEscort's post
White line 22mm rear sway bar install....
It is very noticeable in reducing body roll while turning but it does not roughen up the ride at all as it does not affect straight line...
Mar 4, 2025
FotoMatt
Brankovic's post
Hey all!! I'm new here. My name is Nikola, I live in Serbia.I drive a 2011 Fiesta 1.25 petrol. I am hoping to learn new things!
Mar 4, 2025
Wow! Well, I will be investigating both switches, but the blue/white one in particular. I have had to replace the blower motor resistor...
Mar 3, 2025
Ohhh how interesting. I had no idea Ford had this test feature. I will try it and see what it says. Still do not know which switch is...
Mar 2, 2025
Mar 2, 2025
My Forscan test showed P0504. Brake Switch A/B correlation code. From what I read, it's saying there's something wrong with the brake...
Mar 2, 2025
An honest mechanic is a rare as a youth pastor who doesn't molest kids.
Mar 2, 2025
party ford se
2014 fiesta 1.6 P219A Code
Also. I did a smoke test into my valve cover and and air intake hose (going to throttle didn't see any vacuum leaks
Mar 2, 2025
Brake lights work as far as I know. No issues with braking. From what I read about it, it indicates a failure in the brake light switch...
Mar 2, 2025
