CathyMae
Please Help!
I have a 2015 Ford Fiesta SE. It has the smart shift transmission. The transmission started slipping between gears. I replaced the...
Mar 18, 2025
Tneeley007
1997 Ford Ranger XLT 2.3 5speed Making engine noise
Ford Ranger Discussions (1983–2011)
Just bought a 1997 ford ranger with the 2.3 4 cylinder. noticed when at idle it makes a like ratcheting sound very faintly coming from...
Mar 18, 2025
Vonkie
No headlights
Good day. I have a 2007 Ford Ranger XLT club cab 2.5TDI. All of a sudden there are no headlights, my parks come's on but no headlights...
Mar 18, 2025
Charles Flournoy
Perk's post
Heating and cooling issues
Hello I have a 2014 ford fusion se, the heat blows out on drivers side but cold air on passenger side. I am trying to get heat on both...
Mar 18, 2025
FiestaBob1968
Random Electrical Issues
Thanks for the picture of the toolset. Since you mention some dry areas, I assume you’re thinking moisture. We’re not much wetter...
Mar 18, 2025
My go to tools for cleaning ground connections. Unless you live in New Mexico, Nevada or Utah it’s something that every Fiesta needs to...
Mar 18, 2025
There are ways to clean injectors - using the fuel rail and the injectors installed on it - but do you need to? That is a personal...
Mar 18, 2025
Vonkie
No Headlights
Mar 17, 2025
Ok, the car has had two warm-up cycles and an overnight soak with Heet in the tank, lines, rail, injectors. And at idle, it is SUPER...
Mar 17, 2025
FiestaBob1968
Hello Handy Andy. Thank you for the information. I suspected it was electrical. The mechanic was not happy that I cleared the codes...
Mar 17, 2025
Scratch
Oxygen sensor
Ford Fusion Second Generation
2016 Fusion 1.5L Ecoboost I was getting the code for the downstream sensor and getting engine stutter on acceleration. Code was slow...
Mar 16, 2025
Again, many thanks for the fuel pump procedure, as well as everything else! I picked up the iso Heet this afternoon and I'm just a hair...
Mar 16, 2025
Just got done looking at several vids about how to do just that. Why? Ever have a time when you needed to drain out fuel? O at least...
Mar 16, 2025
jremi24
Cigarette lighter, USB port - Not working
Well…after checking all fuses and power, I decided to go way overboard and remove the entire USB,Cigarette,Sync hub out of the and clean...
Mar 16, 2025
Q
qmfosejs
2013 ford fiesta SE hatchback (North America) no power to USB, lighter, and entertainment system
Hey yall, so I am having some issues where I am not getting any power to my front USB, lighter, and the CD player portion. Everything...
Mar 16, 2025
