rcountryman
powershift transmission...tranmission malfunction service now...
Sorry to hear about the fail on the bearing. You raise a good question about the "difference" between the Black Orange and you using...
Mar 9, 2025
rcountryman
May go ahead and replace them as wont take much time if I buy the removal/installation tool...although I know I saw a vid while back of...
Mar 9, 2025
rcountryman
Finally got transmission out and apart. Found the clutch release bearing blew apart. Got the LUK clutch assembly from rockauto. Got one...
Mar 8, 2025
"Engine Malfunction" on radio for 2012 Fiesta S sedan
I didn't even think to check the clutch switch...yes, it's a 5 speed. I have not ever thought about checking for idle speed. And no, I...
Mar 7, 2025
Nickhead551
5 speed manual transmission problem.
93 k.
Mar 6, 2025
party ford se's post
2014 fiesta 1.6 P219A Code
Thanks very much for your response. I noticed the exhaust had been welded around the resonator and CAT converter area but a test of...
Mar 6, 2025
All Fiesta 5 Speed Same
What may make the Numbers different is the type of differential - some have Limited Slip (LSD) or use a regular standard differential -...
Mar 6, 2025
How many miles on the car? You shouldn't be losing fluid. I suspect it's leaking somewhere, even if you can't see it. It often comes...
Mar 6, 2025
Nickhead551
My 2019 fiesta s is having problems. When it is really war, from driving in rush hour traffic, it becomes hard to shift out of gear and...
Mar 5, 2025
party ford se
Mar 5, 2025
OK, the "pending code" may drop off - remember it's testing the system, or continue to be present until those other emission and engine...
Mar 4, 2025
The faults will eventually set another check engine light for other issues of performance - but right now it may be as for a flimsy seal...
Mar 4, 2025
IT may range from a simple exhaust manifold leak onto a timing of the cam advance solenoids problem - you'll need a better diagnostic...
Mar 4, 2025
dragonfly0201's post
Well, replacing both switches, unhooking the battery for 15 mins DID NOTHING. I don't have a clue what to do now.
Mar 4, 2025
OK, to add more. To set that code means one of the brake switch switches that should be engaging when you hit the brakes - is not...
Mar 4, 2025
